Does the H3000 use a battery to hold the patches and presets? If so does anyone have the battery info? Service manual and owner's manual make no battery mention. But usually gear from this era always had battery backup. Any help appreciated.
Thanks
Thanks
It uses a special memory chip with a built-in battery. Since these batteries usually last about 10 years, they will probably need changing by now.
This chip is listed in the Eventide Store:
http://www.eventidestore.com/remeforh3se.html
Wow kind of a steep price. Does Mouser, Digi-key, etc carry the Ram?
Sorry - don't know.
Do you have a Manufacturer and part number?
Thanks
Just look at the number on the old device. I work as a bench tech and replace these all the time, a common component used in all kinds of products. I have a 3000 but it's in a rack and not accessable. I believe the device in question is a "NOVRAM" Not sure of your level of experience but it's usually socketed, either a 24 or 28 pin DIP device.
Wish I had a service manual for my 3000 so I could be of more help.
it's a future repair from a customer so I don't have the H3000 here in front of me.
I have a pdf of the Service Manual. I can email it to you.
Thanks PDman.. I appreciate that..... send to glennfin@triad.rr.com
One more thing I wanted to mention. Hopefully, the NOVRAM only contains the user preset data in which case you should be able to drop in a replacement. If there is code in there besides the preset data, you'll have read the old device into a programmer, then program that code into the new replacement device. You may know this already judging by your comment about the .bin file.
Thanks.
Glenn
Hmmmmmmmmm P.M. doesn't seem to be activated...
you can reach me directly through my website;
www.glennfin.com
Sorry Marcus - we don't support H3000's on this forum - they are too old (usually 20-25 years).
I would suggest you talk to your technician and see what he means by CI. Otherwise you can send it to us for repair, but that may prove too expensive.
Hey Marcus, I have written Eventide to get the old code for these great effect units. I can program the NVRAM chip and the other ones if I can get the code from Eventide. I will let you know. The NVRAM stores presets I believe but like someone mentioned there might be code to allow access to the chip. Let me know if you are still having this problem. Ben
