H9 - very serioulsy considering a purchase. I thought I'd ask you guys some questions.
Hey I'm  Rob
I am really considering getting the H9 MAX. I don't see any point fucking about with the other ones.
I use a pedal switcher the BOSS ES-5. It's a five loop pedal switcher with midi control as well.
I really need the H9 to intergrate with this part of my rig. I am a barbarian and have never used any midi switching pedals so I have zero knowledge on how easy it is and I am unaware of any potential pitfalls.
Does anyone on here have any experience with setting up the H9 with Boss es-5? I use the editor app on pc to make all the changes but like I say, my lack of midi knowledge makes me think that this may be beyond me. So any help would be appreciated.
Some other questions
  • Is this device dry through or hard buffered?
  • How oftern do eventide add new algorithms?
  • and does any one know how long they are planning on supporting the unit for.
  • I saw some fuzzy algorithms on the fx list. What are the dirty sounds like on this, most digital distortion sounds like shite, to me at least.
  • Am I right in understanding that you can only use one algorithm at a time.
Anything else people think might be helpful I really would be greatful cos I am in a quandry at the moment.
Thanks Robbi
MIDI is easy, you can learn it, and the Boss can control the H9.
The H9 has a switchable option for true-bypass. You lose reverb tails though, for obvious reasons.
You are correct, one Algo at a time.
The Dirts are fine, FOR DIGITAL. there are some gnarly options.. but I use different pedals, beacuse anaolg gainstages are better.
In re your other questions: YOU SHOULD EVALUATE THE PEDAL BASED ON WHAT IT DOES TODAY.
Assume NO support.. (although Eventide has awesome support), and assume NO updates (although there is maybe one a year?).
It is worth it based on what it can do right now, if you ask me. People get hung up on the future possibilities as if it is a dating site or something.. but it is a stomp-box. It does what it does :) If there are additional algos released- bonus, but you arent buying ~them~, you are buying what exisits today..
Several of the H9 algorithms are also multifunction containing gainstage, pitch, delay, for instance.
Sculpt has a nice distortion scheme. In all, 51 current algorithms will keep most people busy for a long time.
Robbi-Rose wrote:
Hey I'm  Rob
Thanks Robbi
The H9 is easy to integrate with a Boss ES-5. I had that setup for a couple of years. The MIDI setup on the Boss ES-5 just takes a little practice, but it is not hard. Just get a basic understand of MIDI and you'll be good to go (P.C. verses C.C. etc).
  • Relay bypass is essentially true bypass. Both options are available throught the settings.
  • They just put out one. No idea how many more or how long til the next one. I think it's been about one a year, generally.
  • Well, they just put out a new algorithm, so they seem to still be supporting it. It is still on a LOT of pro boards; player interest in them seems to keep on keepin' on.
  • Pretty digital, but there is some good nasty fuzz tones in there, especially the fuzz octave sounds.
  • Yep, but it is more complex than that as some of the algorithms are made up of multiple effects which you can initiate via an AUX footswitch or expression pedal, so you can more or less use it like multiple effects at the same time.
