All seems Ok when I udate the TF
When i go to 46.1-- 46.2 --47.1 etc ....i have not the new preset...
don't uderstand. Helppppppp
Only needed to initialized TF and now i have the new prests...
It is worth Remembering to back up any custom presets and make a note of any midi or global configs before you do an initialize because you will loose them during the initialize process.
You can then reload them.
Hello friends,
I have the same issue, however I do not wish to do a full Initialize, to avoid the hassle to re-enter all my settings, aux mapping and presets.
Could the new Floyd Presets be made available to registered members/ pedal owners in the form of a .zip file, in order to be able to be individually loaded via the FLib software as and where they are required?
Mysteriously, there doesn't seem to be a way to delete individual presets using the pedal.
If FactorLib works for you, you could send it your presets, delete/renumber the ones that are hiding the Floyd presets, reinit the unit, then send them back.
In the fullness of time, we will update FactorLib with the latest presets.
I do not yet have access to the floyd presets, because i had already used my own within the banks allocated to these (46:1-50:2) and therefore the only way to see them would be to re-Initialize the pedal.
However, I have noticed that during the update, ONE floyd preset wad entered, in a position that by accident was not changed/renamed from the original pedal 3.0 presets.
Therefore my question is: what would be the manner in which one could manipulate and reset the relevant presets (46:1-50:2) so that the Update Utility considers them as "original" (not altered) and updates them with the NEW floyd ones (without changing the rest of course)?
I ve make a kack up of my preset in Factor lib before reinitializing.
Make a back up after reinitializing, send my first back up to TF and send the new floyd preset after.*
(excuse my english ,hope you understand!!!!).
