Hello,
I have aquired a dsp4000b, which i want to use with vsig. I have managed to download the database over midi, and can dump in programs. I have then made quick test program which dont get to work.
I am rather new to this, so perhaps there are some obvious mistakes, however this is the program:
[View:http://maggie.higen.org/file?id=991CE96B4B704F0818D9E8C9A733F77A:550:0]
and this is the error i get:
don't know about an operator type '2'
ERROR- no operator of type 2.Line 9
is there an error in my program, or do i have a bug in the midi or anything`??
Since you have no line 9, I'm have to assume that it is some kind of MIDI issue - this will probably be related to your computer. Apart from trying another computer or another MIDI interface, it's hard to know what to suggest.
Hey,
Thanks, then i will go hunt for more midi interfaces!
Seems for me that quiet many usb midi interfaces are struggeling a bit with sysex.
Rgs
Egil
Hello,
I must add some more weirdness, which leads me to believe its not the midi interface.
I have tested three different midi interface now, 1 midisport 4x4, one rolan um-one mk2 and one that is on my PCI soundcard. They all give same problems. However if i download a patch/.sig file from internet and do send. it always works?!?!
i can send huge patches with no problem at all?!
Could it be that the vsig editor dont work properly for dsp4000, perhaps i need an older version? i have also tested version 2.0 of vsig, same problem there.
Rgs
Egil
A 4000B (as opposed to a 4000B+) is now very old, so it's hard to know what it will do.
That aside, my first guess was a MIDI problem which now looks less likely.
Next guess is a problem with the downloaded database - you should maybe try to delete the original one (see Preferences to find out where it is) and then download it again.
